November 18, 200619 yr Has anyone got any tips on oil and filter change!When i take the casing off its hanging from cables,and the gasket needs cleaning off.to me this is putting strain on the cables,twisting and pulling.Also bits of the gasket need cleaning from the casing.Just wondered what other 4rt owners do?
November 18, 200619 yr Has anyone got any tips on oil and filter change!When i take the casing off its hanging from cables,and the gasket needs cleaning off.to me this is putting strain on the cables,twisting and pulling.Also bits of the gasket need cleaning from the casing.Just wondered what other 4rt owners do? If you read the manual again it tells you where to disconnect the ignition cable at a plug near the rear brake reservoir. I missed it aswell on my first oil change and thought it was a bit gash on Honda's part, so I re read the maunual and all was revealed. Simple enough job though.
