315 Float Levels
Hello....
..whilst cleaning the carb out today...I snagged one of the float level arms and bent it quite a bit....
...can anybody advise how to straighten and reset the level?....is there a datum or measuring point?
..can't believe I've buggered it before I've even rode it..!!!!
Cheers,
The float level is 18.5 mm or .73 in measured from the surface where the bowl seals. Just use some needle nose pliers to straighten the arm that you bent, its not rocket science.
