Scorpa Easy Problem
hi just wondering if anyone could give me some advice on my scorpa easy, think it 99 model. The bike starts perfectly 1st time but, after about 10 minutes of use will cut out, it kicks straight back up but will just keep cutting out ever 3 or 4 minutes after but, like i said kicks right back up every time. Any adivce would be GREAT!!!! thanks
  • 2 weeks later...
Hi. Try cleaning out the slow running jet in the carb the hole is very small and gets blocked very easily. If this is the problem the tickover will also be improved. another area to look at is that magneto coil may be breaking down as it heats up. Please take a look at scorpa not running for my comments on that problem.
Edited by ukroy
check for cracks in the rubbers round the carb ( take off and inspect carefully) this age of bike could easily need a replacement inlet!
