December 20, 200619 yr hi everyone My sherco has been runnign poorly for the past few weeks, we've stripped it down twice and cleaned out all the jets and the carb. We've also moved the needle setting back to standard as we had to move it when we first got the bike. any suggestions welcome thanks.
December 21, 200619 yr I would put the clip back to where it was and look for something simple, like new plug, bad gas,clogged air filter, clogged fuel filter, bad cap on the coil. Tell us what it sounds like, is it wuah,ning,wuah,ning or more like potato,potato oh wait thats a Harley
December 21, 200619 yr Think you forgot : ring ring ring, ring ring ring, dooaaaa! Is the bike misfiring or just not running smoothly like it normally does? Edited December 21, 200619 yr by John.B
December 21, 200619 yr Author The bike seems to tickover for about 10 secs and then seems to just die like its starving for fuel.
December 21, 200619 yr You did turn the fuel tap on did n't you Have you checked the filter on the carb where the fuel line attaches. Sherco changed the ignition systems on the 04 bikes to Leonelli, might be worth checking the stator and like Brian R says, have you checked the plug, cap and lead. Also if you have a kill switch fitted is that playing up. Edited December 21, 200619 yr by John.B
December 21, 200619 yr check the float needle valve by removing the carb and blowing down the fuel pipe, air should pass freely with the carb the right way up then turn the carb upside down and it should stop, then it sounds like you need to adjust the air screw, get the bike nice and warm, turn the tickover up ever so slightly the adjust the air screw in or out until the bike ticks over at its fastest. do all the adjustments without touching the throttle. it should then sound like, yyyyiiiiinnnngggg, Edited December 21, 200619 yr by paul w
December 21, 200619 yr Connect carb minus bottom to fuel line and check fuel is getting through, dellortoshave a fuel filter is it clear?
December 22, 200619 yr Author Checked the fuel filter and the stator just don't no whats wrong going out on it tomorrow so we'll see whats what and have a play around with it .
December 22, 200619 yr Just had a thought, when you cleaned you carb did you blow through the two very small holes situated on the mouth of the inlet side of the carb (airbox side). They can easily block as they are very fine drillings. I think if I remember correctly, that one is connected to the pilot jet area which if blocked may cause erratic pickup from tickover. Sometimes I find a slime like substance is blown out on my carb when I do this. If you have already done this then apologies. Good luck. Have downloaded this link, page 15 shows the two holes in the carb inlet mouth. Link to Sherco website. http://www.sherco-moto.com/downloads/wayne...nstructions.pdf Edited December 23, 200619 yr by John.B
December 23, 200619 yr Author My bikes running fine now we've done some of the things you lot have suggested. Thanks for all the help guys.
January 2, 200719 yr Author the mixture screw was right in tight so we turned it 2 and a half turns out then set the tickover till it was running fine.
January 2, 200719 yr . Sometimes I find a slime like substance is blown out on my carb when I do this. If you have already done this then apologies. Good luck. Interesting point John, does the UK use a additive in the fuel for winter ? I think the ethanol they add over here in winter absorbs moisture, and it pools in little gel like droplets. Keep fresh fuel in the bike, and dump the old stuff in the car, it can cope with it better.
