January 9, 200719 yr Will it fit? Different spacers? I know the rear sprocket fitting is a 6 hole on a 315R and a 4 hole on a 4RT, but is the rear hub wider too Only that I've got a brand new 315R wheel/tyre/disc/sprocket sat in the garage loft and wanted to see if it'll fit my 4RT Any help greatly appreciated from those in the know
January 9, 200719 yr Providing its from a post 2001 315, its straight in same spacers, don't let anyone tell you otherwise. 36 spokes and 6 hole sprocket doesn't make any difference apart from being a bit stronger.
January 9, 200719 yr Author Providing its from a post 2001 315, its straight in same spacers, don't let anyone tell you otherwise. 36 spokes and 6 hole sprocket doesn't make any difference apart from being a bit stronger. Thanks Subira, It's from a 2004 Mont A dealer told me today that it wouldn't fit, but I was sure he was wrong, as another said it would
January 9, 200719 yr Author you rang the wrong dealer,subira has done it ,so he knows Official Montesa dealers......................you're right, Munch - one said yes and the other said no Thought it better to ask the real world - Trials Central Members
