Sherco 290 '03 Lighting Upgrade?
Hi.
Has anybody fighted some 'bright' headlights to the above? If so, what kit did you use? Wattage? Extra running gear? Problems? Cheers
Bumpo!
I could not help but check what (watts) my original lamp was. Surprised to find a 5 watt peanut.
With elimination of the stop lamp and tail lamp, you should be able to increase that to 10 watts, possibly even a halogen lamp, without killing the ignition when you turn the light on!
Best I can tell, there is no separate lighting coil on this setup, one power source runs everything!
:wacko:
Found this tidbit. You could run 2, 6V/ 5W halogen lamps in series, or 1, 12V 10W!
Or perhaps 2, 12V 5W in parallel! With two, you could look like a 747 coming into the section!
http://lightbulbsdirect.com/Merchant2/merc...gory_Code=MR-11
linky
Edited by copemech
Too Funny...Copemech....
I think I will just start fiddling about...and stop when something melts.
I like the idea myself. Imbedded into a CF front plate, these could be wicked!
I often ride till dark! Have often wished I had the stocker!
