Rear Shock And Nicosil Barrell Question
Just 2 questions folks
What is the spring weight in lbs for a standard trials bike for Mr average weight - 12.5st ish
How can aluminium from a siezed piston be removed safely from a nicosil barrel without damaging the nicosil with emery cloth ?
Thanks as always
Edited by gasgas249uk
The chromium barrel is far harder than the aluminium piston left on it so fine emery paper will do no harm. The effect of the piston seizing will already have done some damage but don't make it worse with vertical strokes, use lateral ones. Chances are the the damage will be below the exhaust port so don't worry - it'll be fine.
a 50/50 DILUTION OF MURATIC(SWIMMING POOL) ACID AND WATER WILL DISSOLVE THE ALUMINUM.
aDD ACID TO WATER, NOT THE OTHER WAY AROUND,
Oops, caps lock! :wacko:
If my memory is correct. Hydrocloric acid will remove or help to flake off the aluminum. Somebody on this forum will confirm or correct my thoughts.
Same stuff, different dilution, what he said!
What Cope said. I've done it before, just take your time.
