Stator, Coil & Cdi Issues...
Has anybody got any experience of electrical faults on later 315's....
...what sort of running problems did you have and what was the electrical causation?
...thanks...
not running and no spark.
Turned out to be kill switch internals had disintegrated
Edited by windlestone
Pressuming nothing simple like loose wire etc I have had stator go on my 97 and friend had his go on a 01 I think. Can get them rewound in a couple of days for
..what sort of symptoms did you get from the failing stators?
...anything specific - cutting out when warm or something sporadic?
I have found that 315's need a resistor type spark plug (ngk ones with an R in the part number) If you don't use these sometimes the motor missfires and generally runs poorly, however if you stop the motor and restart it it will be fine again for a while. If you fit the correct spark plug you get no such problems.
I seem to re call when stator went I had a couple of problems starting, especially when it warmed up and then died all toge then and had long push home!!! :banana2:
