January 31, 200719 yr hi there can anyone help with the rear brake on my 307 i have replaced the disc [chunks missing] also the caliper[ ouch ] pistons atacked with hammer , pads ect, but tried to bleed it out and i am geting nowhere when ipush the plunger on the syringe it goes so far the fluid leeks from the nipple, i have loosend the res cap and backed the ajuster up but still nothing what am i doing wrong ?? Thanks in advance martin 305/7
January 31, 200719 yr sounds like the master cylinder try backing the adjuster off and try again if not might need replacing i fitted a beta one on mine they fit straight on, so does the front caliper
January 31, 200719 yr Author thanks garver19 do you know what model beta master cylinder fits the 307 fantic cos i got caliper ect from bill pye . cheers martin
