Front Wheel Spacers
Okay...it's been a few days since I took apart the front end to repack wheel bearings and now I'm clueless as to which wheel spacer goes where?
The parts diagram doesn't really specify which side is which.
I need to know which side does the longer spacer go on? The rotor/disc side? Yeah...I'll pay attention next time! haha
Edited by biff_rogers
The way it FITS! The caliper has to align with the disc, so go figure!
Clue " L=L", from the front!
did you measure the spacers I have 2 spacers the same size
and it was fitted one spacer and a steel washer on the non disc side.
thats from new, wondering weather to take washer out, obiviosly there for a reason.
will get new spacer made first , good old beta
I'm a little confused? :thumbup: is the washer offending you? :thumbup:
The spacers on the front wheel are the same size and the washer goes on the
right hand side,this is fitted when the speedo drive has been removed!
