Sherco Front Wheel On A Beta ?
Does anybody know if you can use a sherco 290 front wheel in a Beta rev 3 ?
Thanks
I think the spacer is different, PM "rlracer" as he will know for sure!
Yes you can. I use the wheel I have as a spare to practice with. The spacers are just a little differant, don't know the spacer size off hand.
  • 2 weeks later...
Thanks
yes you can they fit everything but a mont,just the spacing is different. hubs are the same and so are the discs, ive just brought two brand new wheels for my scorpa only problem is they leek like a siv on the tubeless back wheel..fitted a brand new irc and the thing leeks out of every spoke including the valve..ive sealed every thing with bathroom sealant and that dont work either..i have put a tube in it now got fed up trying to seal the rim..does anyone know how to fix this problem???
Yes!
Yes!
yes!!!god damn it whats the secret???thankyou verymuch
Be sure you have not poked holes in the rim band with the tire irons! Inspect it closely! Clean it all up good as new and follow instructions! linky
Use soapy water and fingers only to seat the band fully(reallllllly soapy)! And you may want to chunk that "collar" thing!
When installing tire, DO NOT TOUCH the band, or you may damage or unseat it! It must be perfect!
Good friggin luck! Practice makes perfect! :thumbup:
Edited by copemech
