Fantic Restoration...that's The Way To Do It....!
Don't know if you Fantic boys have seen this on the net, but..
Take a look at this gents Fantic 303 restoration..100% superb work.
Flawlessly Documented..good 20 minutes of reading.
All with the help of a trusty Black and Decker Workmate.
And a lathe..and welding gear..and some excellent jigs.
No fridge in any of the pic's or cold Stella..?
Have a browse here.
http://home.quicknet.nl/qn/prive/sw.zeinstra/
Makes you want to spend forever restoring..
Cheers Chaps
Motosinge83.
Bas is also here on trials central. I would have found a new frame; Bas, strripped, cut,straightened and rewelded etc etc. Hes modded the exhaust like a works 303. You cant se it on his site but hes actually done 2!!!! Bits he didnt have he made....longer than sourcing as used part but better than new. titanium kickstart etc
I will be nice to him and see if number 2 can come down from den helder to frankfurt!!!
Hi bas! want to tell us more? Is "my" 303 running yet? ;)
Lee
Yes Lee it is running and much better then before, other jetting makes the difference.
And yes indeed No fridge or cold Stella. If you want a cold one go to Peter schwarz in Germany, nice guy with a large fridge and it is never empty.
He is the main supplier for a lot of parts which i needed for mine restoration.
URL of the site is : www.fantic.nl
Two pictures of Fantic number two.
luv it luv it luv luv it luv luv
we are gonna try and run an air cooled mono trial in Gressenichin september/october
still a long way from den helder though......
