May 26, 200719 yr I just purchased a 99 beta 250 techno and the spark is very weak or none at times. where can I find a wireing diagram for this machine? I was told its probably the stator but do not want to buy 1 if I am not sure. could it be the CDI? the wires are all hacked up and has a wierd resister type thing coming from the fan wires ? Is it worth fixing or should I sell it? Thanks Al
May 26, 200719 yr Protrax, Is the bike running? its unlikely you will ever see a big fat spark form the plug even on newer bikes so dont think its the plug/wiring just by the spark. If the bike isnt starting at all it could well be the stator or something else fueling etc etc. give some symptoms on here and somebody might be able to help, the stator can be rewound or at the worst relpaced (
May 26, 200719 yr Author Protrax, Is the bike running? its unlikely you will ever see a big fat spark form the plug even on newer bikes so dont think its the plug/wiring just by the spark. If the bike isnt starting at all it could well be the stator or something else fueling etc etc. give some symptoms on here and somebody might be able to help, the stator can be rewound or at the worst relpaced (
May 26, 200719 yr Cheapest way is to get it rewound, not sure where you are but doubt its the UK re; the snowmobile? have a look through some of the posts on Beta or do a word search on here and you might find a company near you who can help.
May 26, 200719 yr Hi had a Beta 200 99 techno with a similar problem although it would start and run occasionally it was the standard fitment kill switch earthing on the bars i changed for a mx type it then ran fine but was sometimes had to start so had the stator rewound West Country Windings
May 28, 200719 yr Author If anyone is interested I will sell the Beta as is for $1000 , I am located in Massachusetts Edited May 28, 200719 yr by protrax
