Cooling System Capacity.......
Anyone have the specs handy for how much fluid the rad, hoses and water pump hold?
I'm experimenting with water wetter: trying to figure how much to add....
ty sirs
last week........it's getting good now
Edited by uhoh7
Can't help you with the coolong system specs but have to say, great job on the extra capacity tank and the seat. Great looking place to ride ... very nice. Looks like the perfect setup for bike and location,
Andrew
Where did you get your seat? And how do you like it?
ty sirs
hehe I'm not telling till somebody answers my question.....
I use a cap full in both of our Pro's
Great pictures!!!!!!!!!!!!!!!!!!
I looked around and could not find the spec for the cooling system capacity. Your best bet will be to drain your cooling system and measure how much fluid comes out.
I found this on the GG website regarding the radiator cap:
The cap is a pressure type cap that helps to pressurize the system. This reduces cavitation at the water pump vane and raises the boiling point of the coolant two degrees for each pound of pressure. If there are no other signs of overheating, it may have lost some tension so what you may want to try first is to add a large o-ring that just fits into the radiator neck. This will take up the clearance. Make sure the flat rubber gasket is in good shape so it seals well. Add coolant just up to the bottom of the neck to allow some room for expansion when the coolant heats up. If overfilled, it's normal for the radiator to release some coolant when the engine warms up.
I'd go with 1 cap full. I used 2 caps in a 640 KTM and 3 caps in a VFR and it dropped the temp in the VFR by 8-9 degrees C.
Now where did you get that tank/seat ! I think I recall it was France, but where and how much ?
btw - the capacity is less than 1 litre
Edited by cdn280
  • 10 years later...
Just put the last of my Motul Mocool in my GG, found this thread useful as its not in the manual...
Sherco hold 450cc as manual says. Gasgas sould be close
