June 21, 200719 yr I have a 2000 model rev 3 250cc and it came with no flywheel weight when i bought it off a jack the lad. Doh. I was wondering if a 270cc flywheel weight would fit my bike? Surely they are the same????? arn't they?
June 21, 200719 yr Flywheel weight should bolt straight on as 270 & 250 have the same ignition system! Dont forget to lock tight bolts as they can come loose! as i found out when it chewed a hole in cover and rattled it nuts off!
