Where Can I Get Rubber Sheet 3mm Thick From ?
For all you DIY's out there , i'm sure youll understand this strange request. :wacko:
I need about a 2 metre sq sheet of plain black rubber which is about 3mm thick .
Any ideas where i can get this from.
Ive already tried the obvious Ebay and one seller there doesnt respond to emails !! <_<
cheers
Hi,try looking on the net for rubber floor mats,try this one www.industrialmats.co.uk.
Look in rs components they have an on line site they will have
some i'm sure i have bought some for work from them in
the past .
Would you not be better with a pair of incontinence knickers? :wacko:
Rubber insertion jointing (gasket material) is what you're looking for, it has a thread through it to make it strong. Without the thread it is probably known as neoprene. You'll be struggling to find it at 2mtr wide, it usually comes in rolls about 1.3 / 1.4mtr wide.
Try here: http://www.ibhs.co.uk/prodtype.asp?PT_ID=8...PageHistory=cat
