September 11, 200719 yr beta rev3 270 yaer 2000 air box.. I'm looking for any idears to keep the muck out of the air box on my rev3 year 2000..i seem to for ever be cleaning muck out the carb and takeing the air box off and washing the inside out.. i'm useing unibond super all purpose silicone sealent when puting the air box back together and around the rear mud guard where it meets the frame also.. Do the new rev3 have this same problem or is just the older modles??? Spoke to lamkins about it and they said upgrade to 06 air box, but wanted
September 11, 200719 yr Mikee, I recall some discussions on this a while ago. Not sure if this helps you but the main idea was to put a drain in the bottom of the airbox so that any water would collect and could be drained out. I can't find the thread at the moment but it might be worth a look.
September 11, 200719 yr Found it ... have a look at this http://www.trialscentral.com/forums/index....box+drain+valve
