billyp Posted September 13, 2007 Report Share Posted September 13, 2007 (edited) Last sunday started sherco, (in sandals, good move) it kicked back like a shire horse. After i had run around squealing like a pig, i came back and it was running real crap, put it in gear and went backwards. Ah, woodruff key, nope. Cant find any thing else. Help! Oh, forgot to say, no spark since. Edited September 13, 2007 by billyp Link to comment Share on other sites More sharing options...
beta bhoy Posted September 13, 2007 Report Share Posted September 13, 2007 Last sunday started sherco, (in sandals, good move) it kicked backlike a shire horse. After i had run around squealing like a pig, i came back and it was running real crap, put it in gear and went backwards. Ah, woodruff key, nope. Cant find any thing else. Help! Oh, forgot to say, no spark since. Link to comment Share on other sites More sharing options...
beta bhoy Posted September 13, 2007 Report Share Posted September 13, 2007 Last sunday started sherco, (in sandals, good move) it kicked backlike a shire horse. After i had run around squealing like a pig, i came back and it was running real crap, put it in gear and went backwards. Ah, woodruff key, nope. Cant find any thing else. Help! Oh, forgot to say, no spark since. its the stator mate,mine did the same Link to comment Share on other sites More sharing options...
peter_gasgas Posted September 13, 2007 Report Share Posted September 13, 2007 timing problem, make sure the flywheel has not moved. Link to comment Share on other sites More sharing options...
billyp Posted September 13, 2007 Author Report Share Posted September 13, 2007 timing problem, make sure the flywheel has not moved. If it was just a timing problem, would i not still have a spark ?. The reply about the stator sounds about right, just my luck Link to comment Share on other sites More sharing options...
sr34 Posted September 13, 2007 Report Share Posted September 13, 2007 must agree sounds like stator unfortunatly not the end of the world though try here http://www.uk-motoplat.com/home.html had 3 done by steve myself not so long ago not had a problem since Link to comment Share on other sites More sharing options...
billyp Posted September 14, 2007 Author Report Share Posted September 14, 2007 must agree sounds like stator unfortunatly not the end of the world though try here http://www.uk-motoplat.com/home.html had 3 done by steve myself not so long ago not had a problem since All Sherco Link to comment Share on other sites More sharing options...
sr34 Posted September 15, 2007 Report Share Posted September 15, 2007 must agree sounds like stator unfortunatly not the end of the world though try here http://www.uk-motoplat.com/home.html had 3 done by steve myself not so long ago not had a problem since All Sherco no all beta but it does sound simular and i know there a common fault on sherco also give steve a ring or if youve got a multimeter there are some tests you can do to check i asume you have checked the wiring on the cut out is not going to earth anywhere ?? just unlpug the cut out wiring then see if there is a spark if not then you could try the checks suggested on steves site good luck Link to comment Share on other sites More sharing options...
billyp Posted September 19, 2007 Author Report Share Posted September 19, 2007 must agree sounds like stator unfortunatly not the end of the world though try here http://www.uk-motoplat.com/home.html had 3 done by steve myself not so long ago not had a problem since All Sherco no all beta but it does sound simular and i know there a common fault on sherco also give steve a ring or if youve got a multimeter there are some tests you can do to check i asume you have checked the wiring on the cut out is not going to earth anywhere ?? just unlpug the cut out wiring then see if there is a spark if not then you could try the checks suggested on steves site good luck Message sent to Steve,(in hope) ive been told its the pick ups on the stator, a common problem on any thing spanish, and there not repairable. Mind you sherco dealer tells me he never sold a stator before and never had a problem with them. umm Link to comment Share on other sites More sharing options...
sr34 Posted September 19, 2007 Report Share Posted September 19, 2007 if its the pick ups steves your man that was the problem with 2 of the 3 sators i had done takes about 14 days for the turnaround from uk but as i said not had a problem since :-)) Link to comment Share on other sites More sharing options...
billyp Posted September 19, 2007 Author Report Share Posted September 19, 2007 if its the pick ups steves your man that was the problem with 2 of the 3 sators i had done takes about 14 days for the turnaround from uk but as i said not had a problem since :-)) Just got reply Steve will send one with his mod on, in exchange for mine Link to comment Share on other sites More sharing options...
Please sign in to comment
Sign In Now
