September 17, 200719 yr Hi everyone, ummm well my gas gas recently started smoking heavily and after taking advice and investigating it myself i found a perished crank seal, so being overcautious i replaced the main bearings, the seal that goes into the crankcase before the bearing on the fly wheel side, the seals that are pushed into the side of the bearings and the four o rings (along with numerous gaskets). anyway after rebuilding the bike and running it for a while i found it was still smoking, so i decided to strip it down again to be 100% happy and found the gear box oil had been leaking into the crank, probably more than originally!!!. does anyone know what i may have done wrong or have any vital tips to ensure i rebuild this thing correctly thanks in advance for any info guys
September 18, 200719 yr Cant help just yet as I've never split a TXT yet but I'm just about to. Need to do the same, replace crankseals, so I'm also interested in any info. According to the GG exploded picture theres only one seal to the fly wheel side and 'o' rings to the clutch side. Is this right ?
September 19, 200719 yr Author Cant help just yet as I've never split a TXT yet but I'm just about to. Need to do the same, replace crankseals, so I'm also interested in any info. According to the GG exploded picture theres only one seal to the fly wheel side and 'o' rings to the clutch side. Is this right ? think i have the same exploded view as you of the crank seal and bearing set up and your right it does only show the one seal and two O-rings, however both bearings have two O-rings each, and unfortunately there are two seals that push into the bearings themselves which cost extra!!, good luck with the work, i've learn't alot already. Oh and if you get really stuck call this number and ask for kev (08712232050), he's the technical guy at gas gas uk and he was amazing......the man knows everything.
September 19, 200719 yr Have you seen the GasGas videos? Have a search around. There's a group of videos showing full strip down and reassembly. Someone will pipe up with the link I should think.
September 19, 200719 yr Cheers guys, foretold is forewarned so they say. I'll search around for those vids bikespace, they sound interesting. Muchas gracias
September 19, 200719 yr Here you go, found it - i think courtesy of the R2W crew: Clicky Here Number 11. Bit big, but worth looking at.
September 20, 200719 yr I'm replacing a main bearing as well ( flywheel side). When you pressed in the bearing where did you line the hole in the outer race of the bearing with. There seems to be two oil passages (one at about 10 oclock or so and one at 7 oclock or so when looking from the inside of the left case to the outside?
September 20, 200719 yr Excellent link Bikespace, will make good training material for my son. Unfortunately doesn't show the crank and bearing/seal set-up but I'm sure I'll suss it out. I'm getting to like the internet now (old school but getting there) ! Cheers mate.
September 23, 200719 yr Cheers R2, I'll give gasgas a ring and see if the same mod applies to the 02 model before I put an order in with original part no's. Crackin web-site by the way.
