September 20, 200719 yr Just bought a HRC programmable throttle body ... came with a CD with 4 maps on it. They are 05rtlex0, 05rtlha0, 05rtlhl0, and 05rtlml0. All ep2 files. the "hl" is obviously standard (everything 0) and the "ex" looks like the extra power map (lots of pluses) but anyone know what the other two ("ha" and "ml") are like? Want a softer response off idle but happy with mid and top end as they are? Or can anyone recommend a good clubman map? Thanks, Andrew
September 20, 200719 yr your reading them wrong im afraid , hl isnt zeros it is the power map on that disc. 250 is the std map all zeros, ex is exh restictors , ha is altitude,ml is the soft one. if you read the manual it tells you
September 20, 200719 yr Author your reading them wrong im afraid , hl isnt zeros it is the power map on that disc. 250 is the std map all zeros, ex is exh restictors , ha is altitude,ml is the soft one. if you read the manual it tells you Thanks Munch, Printed out the manual this morning and see what you are saying. Will try the ml map and see what I think. Andrew
