September 23, 200719 yr i've removed the wheel to inspect the play, all the needle bearings look fine, all i can find is play (up & down) in the bottom shock absorber bolt, so i need to remove the bush thing which the bolt goes thru to replace, hows the best way to get it out?
September 25, 200719 yr If the bottom shock bush is worn, carefully remove the two shouldered washers on either side of the rose (spherical) bearing, use a couple of screw drivers to prise these off, do not try to twist these, some of the washers are serrated. The rode joint can be pressed out in a vice with suitable sockets to act as pusher and as a hollow unit to allow the joint to be pushed out. As Heath said, use a good water proof grease on assembly, as with all of the bearings in the linkage area, and head bearings. I use blue water proof grease called Mobil HP. Bye, PeterB.
September 25, 200719 yr Hi Peter Do you know if that bush available as a part from Gas Gas? I replaced all of the dog bone bearings recently but couldn't find out if that bush was available. Otherwise, is it a job for a standard bearings-type place? Cheers Andy
September 25, 200719 yr Hi PeterDo you know if that bush available as a part from Gas Gas? I replaced all of the dog bone bearings recently but couldn't find out if that bush was available. Otherwise, is it a job for a standard bearings-type place? Cheers Andy hi andy just done all my linkage bearings and the one you want GG call eye ball bush, cost me
September 26, 200719 yr Author starngely i've replace the bolt and its fine, ive got a blown up diagram of the swingarm and its showing the ball joint on it,
September 26, 200719 yr Hi Andy, The rose (spherical) bearing for the shocks are a special size, std bearing suppliers do not have this size in their stocks. Bye, PeterB.
October 5, 200719 yr hmmmm i have some very slight movement up and down, i think i'm going to replace my bottom shock bolt, i never even thought of doing that tbh thanks guys (Y)
