September 28, 200719 yr The wheel bearing size for front wheel o3 sherco? I reckon british bearings of the same size must last longer. thanks
September 28, 200719 yr Does anybody know????????..why this is in the scorpa forum????? By the way.... 6004 2rs from memory
September 28, 200719 yr Author Ta, i guess from the smiley you know its right, Scopa?, must be the S then
September 28, 200719 yr Not sure of exact measurements but the ones you want are 6004 2RS if you search ebay for something like Sherco wheel bearings you should get three places that sell them.
September 28, 200719 yr racingbetaboy these bearings are brilliant, i get mine from this guy all the time!! highly recomended!!
September 28, 200719 yr whatever bearings you get make sure you carefully remove the seals and repack them with a decent grease, preferably that blue waterproof stuff you can get. It may cost a bit for a tub but is worth its weight in gold the amount of time/money you will save changing bearings.
September 28, 200719 yr Personally wouldn`t put "chain spray" anywere near my bearings! And although a fair price for a good name bearing I bought 10x 6004RS for my Beta off ebay about a year ago for about
September 28, 200719 yr Here you go something like this would be great if treated to the right grease like THIS why not use chain spray?? its sticks like glue. Because it has no quality's as a bearing lubricant? probably has a much lower boiling point, certainley isn't a grease and with it's slight tacky texture could attract more dirt and dust than and high quality waterproof grease could keep out! Think about it for a minute......... There we are common sense sinks in, you have a moving bearing with load on it that see's all sorts of crap coming its way.... what would be better spending a tenner on a tub of grease that will do all your bearings for years to come packing them full to prevent any damage or spray some fluid in there that may well disperse within days? Edited September 28, 200719 yr by barrybaines
September 28, 200719 yr whatever bearings you get make sure you carefully remove the seals and repack them with a decent grease, preferably that blue waterproof stuff you can get. It may cost a bit for a tub but is worth its weight in gold the amount of time/money you will save changing bearings. A good tip and correct use of correct material waterproof grease is spot on. When removing the seal cover fit to the inside face so the untouched one is outside. (Even perce does this greasing and he is not reknowned for his fettling!) Edited September 28, 200719 yr by Nigel Dabster
September 28, 200719 yr The wheel bearing size for front wheel o3 sherco?I reckon british bearings of the same size must last longer. thanks I really cannot think that there is a british manufacturer left who produces bearings.
September 28, 200719 yr Here you go something like this would be great if treated to the right grease like THISwhy not use chain spray?? its sticks like glue. Because it has no quality's as a bearing lubricant? probably has a much lower boiling point, certainley isn't a grease and with it's slight tacky texture could attract more dirt and dust than and high quality waterproof grease could keep out! Think about it for a minute......... There we are common sense sinks in, you have a moving bearing with load on it that see's all sorts of crap coming its way.... what would be better spending a tenner on a tub of grease that will do all your bearings for years to come packing them full to prevent any damage or spray some fluid in there that may well disperse within days? well, thats told me, how come raga recommends spraying them with chain spray and so does bou?? Edited September 28, 200719 yr by fozza321
September 28, 200719 yr Here you go something like this would be great if treated to the right grease like THISwhy not use chain spray?? its sticks like glue. Because it has no quality's as a bearing lubricant? probably has a much lower boiling point, certainley isn't a grease and with it's slight tacky texture could attract more dirt and dust than and high quality waterproof grease could keep out! Think about it for a minute......... There we are common sense sinks in, you have a moving bearing with load on it that see's all sorts of crap coming its way.... what would be better spending a tenner on a tub of grease that will do all your bearings for years to come packing them full to prevent any damage or spray some fluid in there that may well disperse within days? well, thats told me, how cme raga recomends spraying them with grease and so does bou?? Never heard that before but just for a quick "my opinion" They will have their bikes rebuilt for each and every ride so maybe your "chain spray" method will work great for say 6 hours? But for the rest of us mere mortals that pay and service our own bikes my method works great for me. And thanks to ND for backing me up on this
