October 3, 200719 yr OK I am too lazy to do the search TC thing. I am trying to put a used Michilin trials tire onto the rear rim of my 1986 TLR 200 Reflex. This is my problem: the bead of the tire will not seat. It is a tubeless tire, the rim is for a tubed tire, and I have a brand new tube in said tire. Is the rim designed in such a way that is preventing the tubelss tire to seat on the rim? Or do I need more than 95 PSI to make it go "pop"
October 7, 200719 yr Hi Zippy, I did the same thing to my 1978 Sherpa. The tubeless would not bead out so I left it as is. Runs a bit wobbly between sections but has stacks of grip. Bye, PeterB.
October 8, 200719 yr Shhhhhhhhhh! I been waiting for him to try putting 150 psi in it!!!!!!!!!!!!!!!!!! DO NOT TRY THIS AT HOME!!!!!!!! Edited October 8, 200719 yr by copemech
October 8, 200719 yr OK I am too lazy to do the search TC thing. Too lazy, and not many replies, how can it be?
October 8, 200719 yr Author Thanks for the replies, sounds like I will have to break down and actually purchase (man that hurts to say) a new proper tubless tire that will bead out on my rim. copemech Posted Yesterday, 09:59 PM Shhhhhhhhhh! I been waiting for him to try putting 150 psi in it!!!!!!!!!!!!!!!!!! DO NOT TRY THIS AT HOME!!!!!!!! I gotta get a bigger air compresser, and if I don't try it at home that only leaves out in public where I would look really stupid in front of people, I like to save that for when I ride a trials.
October 9, 200719 yr Zippy even if you do manage to get the bead to go up on the rim with high pressure, there are many people who have found that it will jump straight back off the rim when you let it down again to go riding. I have seen a novel approach recently using four tyre clamps that kept a tubeless tyre in place on a tube type rim not that I would recommend it though!
October 11, 200718 yr I'm kinda surprised at this, I've got a tubeless on the back of my TL and it went on just fine.
October 19, 200718 yr Author Since I am not using this bike and tire in trials comps. I have decided that 25 psi and a rim lock seem to hold the tire to the rim well enough for my uses. Basically put put around yard and maybe some trail rides (slowish)
