October 5, 200719 yr Good Morning Folks, Does anyone know where i can get a good deal on trials bike tyres? Any names of wholesalers with good delivery times? Thanks WRC
October 5, 200719 yr Author Are you in the UK? I'm in the UK. Wales. The trials tyres on my bike at the moment say tubed tyres. The valve has a locknut on the outside, obvliously being an inner tube there. If I was to buy a tubeless tyre what do i have to do, get a valve fitted at a tyre garage? What about the adjustment on the spokes will air escape hence do i have to stick to tubed tyres? Thankyou WRC
October 5, 200719 yr Are you in the UK? I'm in the UK. Wales. The trials tyres on my bike at the moment say tubed tyres. The valve has a locknut on the outside, obvliously being an inner tube there. If I was to buy a tubeless tyre what do i have to do, get a valve fitted at a tyre garage? What about the adjustment on the spokes will air escape hence do i have to stick to tubed tyres? Thankyou WRC What bike do you have? All these questions wouldn't be asked if you filled your profile out!
October 5, 200719 yr Author Are you in the UK? I'm in the UK. Wales. The trials tyres on my bike at the moment say tubed tyres. The valve has a locknut on the outside, obvliously being an inner tube there. If I was to buy a tubeless tyre what do i have to do, get a valve fitted at a tyre garage? What about the adjustment on the spokes will air escape hence do i have to stick to tubed tyres? Thankyou WRC What bike do you have? All these questions wouldn't be asked if you filled your profile out! Sorry pal. Will fill out rest of my details. Scorpa SY250 2002
October 5, 200719 yr OK then the front should be tubed the rear tubeless. My guess is the reason your rear is tubed is because it has previously leaked (probably through spokes) and the previous owner has just chucked a tube in it. Many a threads in the mechanical threads in here to solve the issues on this have a look around you should find the solution so long as you are patient with your working techniques and methodical
October 5, 200719 yr Author OK then the front should be tubed the rear tubeless. My guess is the reason your rear is tubed is because it has previously leaked (probably through spokes) and the previous owner has just chucked a tube in it. Many a threads in the mechanical threads in here to solve the issues on this have a look around you should find the solution so long as you are patient with your working techniques and methodical Thankyou
