Cooling Fan Switch - Common Part ?
The cooling fan switch has died in my Gas Gas TXT280 edition '02. Gas Gas USA want $73 for a new one !
The same part is #14.44 ( approx $25 ) in the UK. I don't mind paying a little premium for spares support in the USA but this is ridiculous.
Anyway - to my question.
Is the cooling switch common across brands ? ie can I get one from the Montesa/Sherco folks, or better still is the part a standard item from a more common application ( bike or car ) - if so what is it ?
Please help if you have any info.
If not I plan on quitting my job and starting up a fan switch import business.
The Gas Gas part number is M0102003. It is held into a cast manifold by a metal clip - no threads.
Edited by gt6racer
do you mean the thermostat if so it can be bypassed which will mean the cooling fan staying on all the time it runs a bit cooler but beats cooking your engine join both the wires on the thermostat start the bike and see if the fan comes on :lol:
Just over $100 Cnd up here, so pricing is about the same. I think the weak US dollar vs the strong Euro is killing you....we here in Canada have just excepted a weak currency as the norm, so expect nothing more :lol:
I'd be a little concerned about running it full time that you might burnout the fan motor which is more expensive again! Perhaps in the interim you could wire a manual switch? But you'd have to be conscious of it all the time.
I ran my beta with the switch shorted out for two years without ever noticing the difference of running slightly cooler. The fan never burned out either.
When I did replace the switch it was one of those like the gasgas that fits in the hoses and I got it from none bike shop source and it was cheap. If only I could remember where I got it. I'll keep thinking and if I remember I'll let you know.
Maybe stating the obvious, why not buy from the UK and then get it sent to you? Should cost no more than a tenner to get it sent to the States, thats about $18?
