December 12, 200718 yr Anybody know what type of plastic it is on the gas gas? the seat unit to be exact, as i need to glue it, its snapped.
December 12, 200718 yr I smacked my airbox a while ago. Right at the bottom. Took it in to a plastic welding place. Fixed it no problem.
December 15, 200718 yr I've never found anything that can successfully glue the plastic, best to get it either replaced or plastic welded. Usually the plastic type is imprinted somewhere on the item, as part of the moulding process. You need to have some of the same type of plastic for the plastic repairer to weld up the cracked plastic (depending upon how big it is). Bye, PeterB.
