Coolant Turning White
when itook the filler cap of my coolant today inoticed there was white milky patches on the top. ichanged and refilled but when i ran the bike for about ten minutes and took cap of again the top of the coolant had gone white again. any suggestions would be appreciated.thanks
sounds like you have got oil entering your water system,check your g/box oil
May be worth dropping the gearbox oil and have a look at that as well, may be the oil emulsifying (sp?) with water if so find the leak between the two before to much damage is done
