Front Spokes
hi all
as usual went over board with the tightening of the spokes and broke them :shutup::o
just realy need to kno were too get a set of spokes (alredy threded) from?
also can anybody give me any tips on fitting them?
nax
Call BVM and speak to "Lawrence" or Rick... they will send you the correct spokes (surely you haven't broken a whole set!!). They can also advise on tensioning them.
As a rule, I give each spoke the "tap it with a small spanner" treatment and listen to the tone they make. As long as they are all making the same tone (and not so high that only dogs can hear it!), then you can be confident they are evenly tensioned. Someone may dispute this technique but it has worked for me for the last 25 years. :shutup:
Also work on the 1/4 turn on every 3rd spoke, until one side complete (3 revolutions) then do the other side. Repeat if still a little loose. Helps keep everything even.
