January 18, 200818 yr JUST BOUGHT A 315r I THIKS IT AN 02 NOW( WAS TOLD ITS AN O1) HOW DO I TELL? ARE THE DECALS THE MAJOR FACTOR? ALSO NEEDS SILENCER( END CAN) ANY IDEAS WHERE ICAN FIND THIS OR ANY SECOND HAND PARTS?
January 18, 200818 yr Welcome mike ! Where to find a silencer all depends on where you are at . Are you in the states ? If so www.lewisport.com can probably can help !! GOOD LUCK , cj
January 18, 200818 yr If you in the UK then BVM Moto I believe sell the WES silencer, alternatively look up WES whom I believe are in Wales. Also worth speaking with Sandifords as Montesa parts are not as expensive as some believe. A new dog bone link was around
January 18, 200818 yr Re: What year? Check the frame number on the headstock - believe the last digits indicate the tear - 01 / 02 /03 etc. As for a silencer - I'd keep half an eye on flea bay, and give BVM Moto a call: 01453 762167. Cheers - Boner.
January 18, 200818 yr have a look at http://www.trialcast.co.uk/accessories.htm for throttle body assemblies.
January 18, 200818 yr Author Re: What year? Check the frame number on the headstock - believe the last digits indicate the tear - 01 / 02 /03 etc.As for a silencer - I'd keep half an eye on flea bay, and give BVM Moto a call: 01453 762167. Cheers - Boner. it says 05 at the end of the stamped numbers(on the frame). and 03 after the letters on the metal plate on the headstock, what one will it be?
January 19, 200818 yr have a look at http://www.trialcast.co.uk/accessories.htm for throttle body assemblies.
January 20, 200818 yr Author That'll help him out loads What with him needing a silencer and all maybe some free advertising!!
January 21, 200818 yr That'll help him out loads What with him needing a silencer and all I've seen the bike and I know that it needs a twist grip assy.
January 21, 200818 yr Belive that'll be an '03 then. Might want to double check before ordering any part... Boner.
