February 5, 200818 yr Has any body got on of these X-BLOK Chain Tesioner Rubbers yet? Are they any good?
February 5, 200818 yr Less prone to get damaged on the rocks because of the angled bottom edge, seems a good idea.
February 5, 200818 yr yes they are worth getting i have had mine on since september its a lot better than straightening them out every 5 minuets Also it is a bit of bling for your bike
February 5, 200818 yr I have one fitted to my GasGas 250 since the dirt bike show. The old one was bent [well the screws and the cover plate were], so I thought I would give it a go. Findings: The rubber is much harder, so no problem with wear, the profile is lower and there is no protruding bolt heads so less risk of catching rocks, plus the bolts and construction is thicker and stronger so it will not bend. It is double the price of the standard, but I think it should last longer in the rocks, and as I have replaced 2 of the standard ones in 2 years, I am hoping this will pay back. So far no problems.
February 5, 200818 yr yeah they are good but you have to re drill the holes on a gasser because they are too small, but apart from that,they wear really well, and look awesome!!
