pazz Posted February 10, 2008 Share Posted February 10, 2008 I have a 1998 Cota 315 and the front brake performance is pretty poor, it's just a plain solid front disc. What is the best option to improve the brake? Can I get get soft pads or is there an option to fit a later "wavy" disc or similar, if I did this would I need different pads? Any ideas please. Quote Link to comment Share on other sites More sharing options...
ham2 Posted February 10, 2008 Share Posted February 10, 2008 I had a 98 and the front brake was poor ,just as you describe. You might want to fault find in the reverse direction to me?!? I fitted: Slave pistons and seals. A wavy disc. A new braided hose. New 4-pot calliper assy'. Different lever. Quote Link to comment Share on other sites More sharing options...
pazz Posted February 10, 2008 Author Share Posted February 10, 2008 fair point may be a good idea to look at the seals, the only thing is I seem to be getting plenty of pressure to the caliper and no bubbles back in the master but it just doesn't seem to want to slow down. I have to chnage the pads as I think they're glazed but thought it may be the right time to try a disc as wel. What wavy disc did you use and where did you get the seals? Quote Link to comment Share on other sites More sharing options...
02-apr Posted February 10, 2008 Share Posted February 10, 2008 I thought this sounded unlikely but it actually works. Ride round with the brake dragging to get it warm then throw cold water on it. You might need to repeat the process but this certainly made a big difference to 2 bikes I've had. Seems it takes all the impurities off the braking surfaces. Worth a try as it costs a lot less than a seal kit. Quote Link to comment Share on other sites More sharing options...
ham2 Posted February 11, 2008 Share Posted February 11, 2008 fair point may be a good idea to look at the seals, the only thing is I seem to be getting plenty of pressure to the caliper and no bubbles back in the master but it just doesn't seem to want to slow down. I have to chnage the pads as I think they're glazed but thought it may be the right time to try a disc as wel. What wavy disc did you use and where did you get the seals? From what I remember the uk importer of the spares was a wholesale operation only, so a mate in the trade had to use his account on my behalf. The disc (I think) was a galfer? Quote Link to comment Share on other sites More sharing options...
pazz Posted February 11, 2008 Author Share Posted February 11, 2008 gonna try new pads, bed them in and use the hot / cold method. If this doesn't work then it's down your shopping list starting with the seals. Thanks for the info, I'll let you know how I get on Quote Link to comment Share on other sites More sharing options...
eiaprilia Posted February 13, 2008 Share Posted February 13, 2008 i just got a new seal kit today from BVM and it only costs Quote Link to comment Share on other sites More sharing options...
pazz Posted February 18, 2008 Author Share Posted February 18, 2008 Put new pads in, bedded them in then tried the hot and cold, seems better but I am going to try the seals. They are original for 1998 and maybe looking for a change as there seems to be a lot of what looks like dirt in the bottom of the master. Thanks Quote Link to comment Share on other sites More sharing options...
pazz Posted March 12, 2008 Author Share Posted March 12, 2008 OK, did the pads, scratched the discs and bedded them in, rode them a while chnaged the seals and then did the hot and cold thing, they were much better. The final thing that did the trick was using them in anger on a muddy trial, after the disc and pad got so scratched and scraped they worked much better. Back as good as new, which aint great but good enough for now. Thanks Quote Link to comment Share on other sites More sharing options...
