Beta Ear Wheel Ettin The ****er Back In!
ive just replaces my rear wheel bearings! any tips on gettin the rear wheel back in!
given up till tomorrow!
Carefully prise the brake pads apart, this will give you a bit of free play with the disc. (But remember to pump the pedal before riding!)
:rolleyes:
unless i havent tapped the bearings home far enough! seems a bloody tight fit!
have another look at it in the mornin,plenty of room between the pads!
maybe just need another pair of hands?
Edited by fastandyc
Chances are you've got the alloy wheel spacers the wrong way round, one is slightly bigger than the other that one should be disc side. Other than that your on your own!
Edited by O.A.S motorcycles
:rolleyes: sorted now! didnt know about the spacers,not sure which way round i got em?
but i went out to the garage1 stared stared some more and then,realized the only way was to drop the wheel in from the top...doh,went in stright away,but i dont know what way round i have the spacers,but everythings turning freely,and the chain seems to be inline!
Is the disc running centrally in the caliper? If it's catching the side (or one side more than the other), you are off centre.
You should be able to see which is the thicker spacer with the wheel in place, definitely worth checking to make sure :rolleyes:
tok it up the stret yesterday,everything seems fine,musta had a blonde moment the other night!!!!!!!!!
Ralph told me this one, big (brake) small (sprocket) never forgot after that little nugget of info
