Domino Slow Action Throttle
Just replacing the throttle on my bike with a Domino slow action
easy enough but there's a small grub screw in the packet??
where does this go ?doesn't seem to be one on the throttle im taking off
bit baffled
any help
thanks
I think some of them came with a little barrel nipple in brass which had a grub screw in it.
Tony
so im assuming this is surplus to requirements
i had put it together it works fine then i find this screw....doh
cheers Tony
I seem to remember mine came with one too, never did work out what it was for??
Definitely a cable nipple. Don't chuck it out, very handy :)
GJ :)
The little "nippel" with the screw is.
If you throtel cabel on the end slipp off, than it is ment that you can repair it. with this littel " nippel"..
good idea, glad i hung on to mine then.
Cheers
i'll keep it somewhere safe
;) It's a cable end to fit the domino tube , so you can adjust your inner cable length if need be or if your stock cable end doesn't fit the domino tube correctly ! They are a one size fits all throttle afterall !!!
Glenn :rotfl:
Edited by axulsuv
