March 17, 200818 yr Guys, was out riding over the weekend and noticed a rattling noise coming from somewhere... Upon further inspection I found it to be the front disc was vibrating as it has a little play. Thought that this couldn't be right - so checked all the bolts and found that they were all tight. So - took it all apart and cleaned it all up so that everything looked as good as new, put it back together again, and it was still loose! So my question is - is the front disc suposed to have a certain amount of play? Thanks - Boner.
March 17, 200818 yr Guys, was out riding over the weekend and noticed a rattling noise coming from somewhere...Upon further inspection I found it to be the front disc was vibrating as it has a little play. Thought that this couldn't be right - so checked all the bolts and found that they were all tight. So - took it all apart and cleaned it all up so that everything looked as good as new, put it back together again, and it was still loose! So my question is - is the front disc suposed to have a certain amount of play? Thanks - Boner. i hate rattles there should be play in the front disc i silicon around the cups of the disc stops the rattles and doesn't affect the braking performance
March 17, 200818 yr Author Ahhh - we'll at least I now have very clean (floating) discs! Thanks for putting my mind at rest on that one! Cheers - Boner.
March 17, 200818 yr i silicon around the cups of the discstops the rattles and doesn't affect the braking performance my mate just bought a 99 mont and his front disc rattles alot........ thanks for the silicon tip,
March 18, 200818 yr In the past i have slipped an o ring between the cuped washer and the disc to quiet them down. Looks a little cleaner than silicone. It is ment to float. --Biff
April 13, 200818 yr Haha, being new to the scene and just having had a few rides out on my recently purchased '02 315R i have also noticed this rather annoying little rattle. Top tips guys!! Many thanks, Ben.
