Best Drum Brakes?
Who made the best drum brakes and what made them better than the others?
I had a tlr which had good brakes, late sherpas with relined hubs and rod actuated rear was good and I am in the process of mating a yamaha ty mono hub to a tubless rim to give the 340 an edge, I hope. Also enablesright rod brake to by opposite to sprocket side. :rolleyes:
Nigel, You started that project last year !
Alan gave me a TLR front wheel. I may have to do some playing. I wonder if it's AHRMA legal?
  • 2 weeks later...
Does this mean a return to the Classic series on the 340 is on the cards for 04? Having ridden the Phil King last year and used virtually every body part against very hard and oh so solid trees as some form of braking device for the Ossa down some of those big slippery drops, I'd suggest you look to finding a mono front wheel for it as well....... :rolleyes: Good trial though.
Looks like they have some good events scheduled next year to hopefully get the series back on its feet.
I'd say most of the 80s bikes had decent drum brakes. Yams, T/S or mono are good, ditto Hondas and most of the European bikes had Grimeca I think, which also work well. They had better feel to them and generally worked when wet, unlike 70s bikes. I guess a lot can also depend on the material used for the lining, of which there is probably a lot more choice nowadays.
I've fitted a TY T/S front wheel to my Ossa and it went straight in with just a new spacer made to fit. It works much better than the Ossa brake, although the bike itself isn't really suited to clutch / brake style riding.
