April 15, 200818 yr Hi can anyone help me whats the difference between the 280 txt and the 280 txt pro Thanks kev
April 15, 200818 yr Hi can anyone help me whats the difference between the 280 txt and the 280 txt proThanks kev Kev, The "TXT" is essentially the older model engine and frame and the "TXT Pro" is the newer, lightweight engine. It's kinda confusing as they call both TXT's, but actually, when the Pro first came out, it was designated as the "TXXI" model (I have an 02' Pro-first year- and the "TXXI" decals are on the radiator guard), but apparently they didn't follow through with that, hense the confusion. Jon
April 16, 200818 yr Author Kev,The "TXT" is essentially the older model engine and frame and the "TXT Pro" is the newer, lightweight engine. It's kinda confusing as they call both TXT's, but actually, when the Pro first came out, it was designated as the "TXXI" model (I have an 02' Pro-first year- and the "TXXI" decals are on the radiator guard), but apparently they didn't follow through with that, hense the confusion. Jon thanks jon but how do i tell which one i have i have 2001 modle?
April 16, 200818 yr thanks jon but how do i tell which one i have i have 2001 modle? You have the "regular" TXT model, also known as the "Edition" model in later years, as the Pro was not released until 2002. Jon
April 16, 200818 yr Author You have the "regular" TXT model, also known as the "Edition" model in later years, as the Pro was not released until 2002.Jon thanks jon for your help
