Leak From Ty250 Gear Selector Shaft
I have an oil leak from the gear selector shaft, is this easily fixed? Is it just a case of pulling out an oil seal and replacing, or will the gearbox need to be stripped.
Any advice appreciated, many thanks in advance.
Shouldn't need to strip the gearbox. Either you'll be lucky and can get it out without removing the shift shaft or worst case remove clutch and shift shaft.
