May 22, 200818 yr hi, are gas gas rear shocks rebuildable? can anyone recommend someone who repairs them or do i have to pawn the family silver and buy a new one? it's for a 2000 txt321 cheers.
May 22, 200818 yr Depends which shock. I had a Sachs (supposedly not rebuildable) which a clever lad rebuilt for me. Answer, take it to a decent suspension tech and ask them.
May 24, 200818 yr Depends which shock. I had a Sachs (supposedly not rebuildable) which a clever lad rebuilt for me.Answer, take it to a decent suspension tech and ask them. Sometimes, if a shock has lost pressure (and supposedly is not rebuildable) the upper body can be drilled and tapped for a Schrader valve, the oil changed and the shock re-filled with fresh Nitrogen. The seals rely on pressure to work and if the seal failure is not due to a nicked shaft, it will be good again, for a while anyway. If the shock has been run without adequate oil, the internals will be worn due to lack of lubrication and the shock is essentially junk. Jon
