June 6, 200818 yr Hi all can anyone tell me if the earlier rev 3's or techno's wheels will fit an 06 rev 3 thanks
June 6, 200818 yr Front and rear here Phill on Ebay, look abit tatty but a second hand rear usually costs 150 Wheels
June 6, 200818 yr I've recently bought a spare rear wheel from an 01 rev 3 and by a little bit of modification to the spacers made it fit an 08. The only noticable difference other than the fact that the spacing is slightly different is that the older discs are thicker, but this has no effect on the fitting or the performance. Sod's law being what it is, we've never had a puncture since we got the spare, but you can guarantee that the first time we leave the spare at home................ Sorry I can't comment on whether techo wheels are the same nor whether the fronts will swap, but I'm sure that someone will have the answer
June 8, 200818 yr You only need to adjust the spacers. The Rev3 has used 2 swing arms with different spacing. My spare is from a 96 Techno with adjusted spacers. PS I have never had to use my spare in 5 years.
