June 28, 200818 yr Hi guys, just ordered a flywheel weight to fit to my 250 pro from gg uk (not the hebo one) and it didnt come with any instructions, being saturday i cant get hold of anyone (kev) to ask. So has anyone fitted one of these? do i need to drill out the holes? do the two inserts go into the flywheel from the front or the back of the flywheel? help me please. cheers guys
June 28, 200818 yr I havent done this myself, but if it can be any help I remember that I read that You have to remove the flywheel the first time to fit something on the back of the flywheel. Once You have done this the wheight can be removed and refitted again without having to remove the flywheel. Hope this help.. -Jan
June 28, 200818 yr Of course I read it here. Quote: "YOU WILL NEED TO REMOVE the flywheel initially to fit the two 'top-hat' threaded parts that need to be loctited in place. Once you have fitted the weight you can take it off and refit without removing the flywheel again." -Jan
