Front Break Problems
Can someone help me out.
I have looked through the other posts but can find answer to my problem.
Changed pads and pistons in front break,I had problems bleeding but I sorted that out.
But the travel on brake lever was way to much for me,so took caliper off to see,pistons on one side only come out.The other pistons move slightly but not much.Also the piston on m/s is at it's max.
Any thoughts please.
Stop press.
Saturday night and I've sorted it.Did not have much faith in the hot then cold trick, but it worked a treat (can relax now).
Edited by coldcake
