August 21, 200818 yr after loads of hunting iv finally got another bike!!! 6 month old '08 250. really like it but its my first beta, do any of you beta veterans have any recommended mods or tweeks???
August 21, 200818 yr Flywheel weight removal (removes the over-run - more zippy - same traction) Trialcast rear brake boot protector (looks nicer - prevents wear on the
August 21, 200818 yr See my threads on clutch modification and ignition modification. Also Vforce reeds http://www.trialscentral.com/forums/index....showtopic=18516 http://www.trialscentral.com/forums/index....st&p=138860 OH yeah also be advised that the Keihin tends to be prone to water in the pilot jet orifaces in the carb body. If the bikes starts running "not as sparky" as usual it's worth pulling the beastie out and blowing out the carb with compressed air as the surface tension will keep it from evaporating. Edited August 21, 200818 yr by Dan Williams
August 22, 200818 yr after loads of hunting iv finally got another bike!!! 6 month old '08 250.really like it but its my first beta, do any of you beta veterans have any recommended mods or tweeks??? Snap, I have just done the same! It looks good but I have yet to ride it in anger!!
August 22, 200818 yr Author Flywheel weight removal (removes the over-run - more zippy - same traction) can you give some more details on this please. I took a look at the flywheel because the chap i bought it off had retarded the timing by a couple of degrees, but I couldnt get the fly wheel off or the cross head screws out of the flywheel. I assume the cross heads coming out would let me use a flywheel tool while loosening the centre nut. Does that sound right?
August 22, 200818 yr Fivemeister....I couldnt agree more. I always take the flywheel weight off mine...much better I reckon. Also reckon the slow action throttle is better too.
August 22, 200818 yr can you give some more details on this please. I took a look at the flywheel because the chap i bought it off had retarded the timing by a couple of degrees, but I couldnt get the fly wheel off or the cross head screws out of the flywheel. I assume the cross heads coming out would let me use a flywheel tool while loosening the centre nut. Does that sound right? Yeah thats right, the screws are really tight though i had to use an impact screwdriver, ive seen people use a grinder, its not pretty plus the weight is unuseable then if you want put it back on.
August 23, 200818 yr The flywheel weight is really tight - try to apply some local heat to it (i used a blowtorch with a small nozzle and shielded the cavity to the electrics) then shock it with an impact driver or air wrench. Don't forget that when the weight is removed you can put the cover back on minus the plastic spacer which has the bonus of making the engine width smaller.
August 23, 200818 yr try to apply some local heat to it Should have said - just to the two screws rather than the whole flywheel weight.
August 23, 200818 yr Author Don't forget that when the weight is removed you can put the cover back on minus the plastic spacer which has the bonus of making the engine width smaller. doesn't the spacer also act as a gasket???
