isaacely Posted September 16, 2008 Share Posted September 16, 2008 Hi, Can anyone explain how to set up my bantam b175 so that it does not need a battery for the engine to run.It is used for trials so does not have lights etc,I am trying to make it as simple as possible without spending a fortune on electronic ignition, can the alternator be connected straight to the coil so I can remove the battery and regulator? Also does anyone know of a source for buying a tucked in high level exhaust or the right size of silencer required or is it just guess work? Thanks for any info replied. Quote Link to comment Share on other sites More sharing options...
