September 27, 200818 yr I am having problems with my 2005 Montesa 4RT, can anyone tell me how to reset the system? So i can try this. Thanks
September 27, 200818 yr It would be helpfull to know what problems you are having? Reset the system!! I presume you mean the throttle body, if its a standard which it was on the 2005 model then you cannot reset it. If it is programmable then you need software maps, leads, computer and a battery...........................................
September 27, 200818 yr Author there is no spark, been on all week, checked everyhing possible - still no spark! Any ideas?
September 27, 200818 yr Have you tried dissconnecting the bank angle and linking cables out,red/white to brown .I think. The only reset i know of is to open throttle fully then slow push down on the kick start let it back up and let go of throttle. Hope this helps.
September 27, 200818 yr That's the reset mode: Open throttle wide; SLOWLY depress the kickstart (don't "kick" it as if to start); Close throttle and leave closed; Kick normally to start... and she should burble into life. Big John
