November 2, 200818 yr Hi Jaan, I have a 1979 348 in the workshop, it has the original fatbars that I will replace with a proper set of Renthal's when I get around to it (It's not at the top of my bike rebuild priorities). If you are stuck for a pair of fat clamps then I may have some for you here. Let me know. Bye, PeterB.
November 2, 200818 yr Author Thanks TooFastTim and PeterB The original fatbars "Super-Akront Montesa" that I have is only 24 mm. As I know the modern fatbars are 28,6 mm. So the original 348 bar mounts are to small.
November 6, 200818 yr Jaan. You need to cotact your fellow countryman Vesty Uk he stocks a set of clamps with secondary bolts in a slot that fit the holes on Montesa yokes for modern fatbars, I've got them on one of my old bikes,no problem. They are anodised light gold and I think are Apico brand. I think when they came they had a half round bottom section which I had to machine off, If you email me I will send you a photo.
