Best Method Of Applying Decals
Hi Folks.
In your experiences what is the BEST proven method of applying new decals to a Beta. Is it the wet method ie: squeezie bottle with a little soapy water or the bone dry method, which can be tricky!!!!!!!!!!!
I don't really want to screw up a good decal kit?
Cheers.
Do it dry for a laugh then post pics.
Me i like it warm wet and slippery does it every time. Oh and a hair dryer whilst workin out the access water.
Better still buy a GasGas.
I did the dry method, worked a treat, didnt even know you could do it wet hehe.
Tom
Hi, I would definately reccommend applying decals using the wet method, you can move them into the correct position, squeeze out any air bubbles then gently dry off with a heat gun but dont get to close. :D:P:banana2:
I found if you use a soapy water on stickers with clear parts it can dry out white underneath.
Water on its own works ok.
