December 15, 200817 yr Which work best with the standard 4RT hangers? In terms of feel/position and not fouling/interfering with k/start Jitsie Hebo Scorpa Raptor Future trial Any others?? Edited December 15, 200817 yr by Johnnyboxer
December 16, 200817 yr Author trialcast.co.uk Great ..............209 views and you're the first to help me out Cheers much appreciated Edited December 16, 200817 yr by Johnnyboxer
December 18, 200817 yr I like Hebo pegs as they are wider than some pegs, comfortable and really strong. However in my opinion you can't get a better foot peg than Raptor. They are wider still, rarely clog with mud and are really really strong. All pegs, i believe, on standard hangers foul the kickstart, you need to carefully file the kickstart to clear the pegs. I have put raptor hangers on, they are rear set and the kickstart misses the foot pegs. The down side is reaching the rear brake pedal becomes a stretch, as i was bending rear brake pedals every other week at one point i've fitted a billet shorter rear brake pedal. You can reach it no problem but you loose a little bit of feel when braking.
December 18, 200817 yr I used Hebo pegs on Rapter set back hangers. Despite what people think Raptor hangers do bend & what used to happen was the kickstart jammed on the footrest when this happened. First job I used to do when fettling was to give the footrests a good crack with a wooden mallet to bend them forward. Standard back brake lever is crap, as soon as it bends you have virtually zero back brake. I first up used a sherco one which is a straight fit, downside was it sits slightly under the casing & I alway thought one good crack & it'd be a new casing required. I then went onto one of the billet ones that Marky Boy sells, 100% correct length for set back pegs & 100% good quality, certainly worth the money spent.
