Gas Gas Vibrating Noise
Hello,
I have a 2008 Gas Gas 280cc txt pro which makes a Knocking/Vibrating noise but when i press the clutch the noise stop, i ve already tried putting high octane fuel in but that did nt sort it, Any ideas what the problem might be or is this normal?
Thanks
Matt
Hello,
Thanks
Matt
Its normal, I think its the clutch plates rattling in the clutch hub, when you pull in the clutch this applies some pressure to the plates and stops them rattling. All my pros have done this
What Baldi is saying is 'they sound like a friggin rattlecan'--normal! Drives me nuts!
Enjoying your kicker Baldi? :D
Completely normal. Sounds like something is wrong but it is the clutch rattling! You'll get used to it!
Thanks for your help, i was worried that it was something bad like the gears were messed up.
Thanks
Matt
