Chain Noise
hi all new to this and first time post hope someone my help, got a 2001 montesa and got a strange noise that seems to be like a rattle sound near chain front sprocket i think its the chain against the protector on the swing arm, chain is at the right tension but has anyone else had this problem....?
Hi,is the front sprocket a bit loose,mine was,it drove me nuts.or it could be a wearing chain. :hyper:
hi yes it is rather loose did you cure your problem cause its drives me nuts keep thinking somethings gonna rattle looose
Hey PP limp wrist, everything was loose on your 315!!! :hyper: No wonder it rattled :huh:
could be the side of the chain hitting the footpeg bolts on the inside of the frame
Hey PP limp wrist, everything was loose on your 315!!! :hyper: No wonder it rattled :o
Cheers bud,i've had the Gasser in bits already!!!!!!!!!!!!!! shud av kept the mont!
:huh:
thanks all for help turns out had two snapped teeth on front sprocket!!!!!!!!!!!!
