January 14, 200917 yr Hi, does anyone know if the middle box on the raga replica bikes are a differnt design to the ones on the standard bikes.. Thanks For The Help Ben.
January 15, 200917 yr Author Anyone? Cheers Ben. It's because i am after getting the carbon cover that is on raga's bike & just wanting to no whether it will fit. i know about the different frame sizes between the 08 & 09 models, but when i saw raga's 2007 bike it had the carbon exhaust on. Edited January 15, 200917 yr by GasGasben
January 15, 200917 yr no sorry, i do not know. it got this email adress by hitting email in the Gas Gas web page: gasusa@gni.com maybe try asking Gas Gas about that. they should know the best. Good luck
January 16, 200917 yr As far as i know, if you want to fit a carbon exhaust you need the separate middle box to do that. If you have a sealed middle box and silencer then you will have to get a middle box and the carbon silencer separately which will cost a bit more! The middle boxes should be the same on all models.
January 16, 200917 yr As far as i know, if you want to fit a carbon exhaust you need the separate middle box to do that. If you have a sealed middle box and silencer then you will have to get a middle box and the carbon silencer separately which will cost a bit more! The middle boxes should be the same on all models. As far as I know, the middle box is essentially the same on all the large displacement models (although, I can assure you from personal observation that Adam's middle box is different from anybody elses). The later systems are one-piece with the final exhaust welded to the middle box. The earlier Raga Replica final mufflers were about 2" longer than the standard muffler. Jon
January 16, 200917 yr Author Thanks everyone I found the raga carbon exhaust on the gasgas powerparts on the spanish website, but all it looked like to me was just a standard silencer with the carbon cover rivited over the top of the cover if it doesn't fit just being standard, i don't really fancy buying a middle box aswell Edited January 16, 200917 yr by GasGasben
January 21, 200917 yr Author right, i've tried to order a JT7 silencer from gasgas uk & there out of stock, so does anyone else no where i can get one from Thanks
